查看: 1307|回复: 0
DEVO F7, GEAR通道对应FMod [3档开关] , D/R [2档开关] , 解决APM 6档飞行模式
发表于 2014-10-27 10:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的DEVO F7, GEAR通道对应FMod [3档开关] , D/R [2档开关] , 设程式混控 , 解决APM 6档飞行模式
Model> Output > Gear (ch5) = FMod sw (Flight Modes)
Function> Travel Adjust > Gear= 65, -65
Function> Sub Trim > Gear =-19.5
Function> Program Max 1 = Normal
All Servo Hold? = Cancel
Master=”Gear”
Slave=”Gear”
Pos 0 < > = 0
Pos 0 <-> = 0
Pos 1 < > = 90
Pos 1 <-> = -110
Offset = -55
Switch Pos 1 = 1 And, 1 D/R sw
FlightModes Setting
Fight Mode
FMod
D/R
F7 Reading
PWM
PWM  Range
FM1
Stabilize
-84%
1164
0-1230
FM2
Stabilize  (s)
-52%
1293
1231-1360
FM3
Alt-Hold
-19%
1424
1361-1490
FM4
Loiter
13%
1554
1491-1620
FM5
Auto
45%
1685
1621-1749
FM6
RTL
136%
2048
1750+
